[GRASS-dev] Docker image based on Alpine Linux with GRASS GIS 7.7.git and wxGUI
Markus Neteler neteler at osgeo.org
Thu Aug 1 10:21:56 PDT 2019
On Thu, Aug 1, 2019 at 1:59 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, Jul 31, 2019 at 11:41 AM Markus Neteler <neteler at osgeo.org> wrote:
>> In fact, $GISBASE/gui/wxpython/wxgui.py isn't present in the docker image.
>> Do you have an idea what to look for (say, what does it (not) generate)?
> Hi Markus, wxgui.py is a file copied from source to distribution by make, so the question is what compilation output says.
https://cloud.docker.com/repository/registry-1.docker.io/neteler/docker-alpine-grass-gis-gui/builds/c8c39f18-33cb-44df-a669-23f8cdc5682f
/usr/bin/install -c -m 644 image2target/ii2t_toolbars.py
/src/grass_build/dist.x86_64-pc-linux-gnu/gui/wxpython/image2target/ii2t_toolbars.py
/usr/bin/install -c -m 644 gis_set.py
/src/grass_build/dist.x86_64-pc-linux-gnu/gui/wxpython/gis_set.py
/usr/bin/install -c -m 644 gis_set_error.py
/src/grass_build/dist.x86_64-pc-linux-gnu/gui/wxpython/gis_set_error.py
/usr/bin/install -c -m 644 wxgui.py
/src/grass_build/dist.x86_64-pc-linux-gnu/gui/wxpython/wxgui.py
/usr/bin/install -c -m 644 README
/src/grass_build/dist.x86_64-pc-linux-gnu/gui/wxpython/README
python3 -t -m py_compile
/src/grass_build/dist.x86_64-pc-linux-gnu/gui/wxpython/icons/__init__.py
/src/grass_build/dist.x86_64-pc-linux-gnu/gui/wxpython/icons/icon.py
/src/grass_build/dist.x86_64-pc-linux-gnu/gui/wxpython/icons/grass_icons.py
There is no error at all...
Anything else I can look for?
thanks
Markus
