[GRASS-dev] [GRASS GIS] #3880: update/drop revision check after git switch
trac at osgeo.org
Sat Aug 3 08:02:36 PDT 2019
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.6.2
Component: Compiling | Version: svn-releasebranch76
Resolution: | Keywords: svn, git, revision
CPU: All | Platform: All
Changes (by neteler):
* priority: normal => blocker
Comment:
The code in question is here:
# include/gis.h
41:#define GIS_H_VERSION "$Revision$"
44:#define G_gisinit(pgm) G__gisinit(GIS_H_VERSION, (pgm))
45:#define G_no_gisinit() G__no_gisinit(GIS_H_VERSION)
# lib/gis/gisinit.c, line 86ff
if (strcmp(version, GIS_H_VERSION) != 0)
G_fatal_error(_("Module built against version %s but "
"trying to use version %s. "
"You need to rebuild GRASS GIS or untangle
multiple installations."),
version, GIS_H_VERSION);
gisinit();
This needs urgently to be addressed since SVN "$Revision$" doesn't exist
any more in git.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3880#comment:1>
