[GRASS-dev] [GRASS GIS] #3884: items selected on drop-down controls not inserted into GRASS command
trac at osgeo.org
Sat Aug 10 12:00:11 PDT 2019
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: wxGUI | Version: svn-releasebranch76
Keywords: wxGUI control | CPU: Unspecified
Platform: Unspecified |
In a number of modules, when you select something from a drop down control
with a mouse, it shows up in the control text box, but does not get
inserted into the actual GRASS command. For the command to work, you have
to either type the name of the item into the control or paste the text of
the name of the item into the control (the latter is made more difficult
because many controls do not recognize key shortcuts like cmd-x, cmd-c,
and cmd-v at least on the Mac). \\
Here are some examples where this is a problem: \\
* selecting image subgroup in multiple image processing modules (i.*)\\
* selecting location and mapset for r.proj and v.proj\\
I'm hoping this is a generic problem with the control rather than having
to find it in every module. I don't know if this is Mac specific or not,
but suspect not. It's been a problem for some time and affects later GRASS
versions too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3884>
