[GRASS-dev] [GRASS GIS] #3883: GRASS master does not compile with Python 3 on Mac
GRASS GIS trac at osgeo.org
Wed Aug 14 14:59:38 PDT 2019
  Reporter:  cmbarton     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.8.0
 Component:  Default      |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by cmbarton):
 Replying to [comment:1 neteler]:
 > I see in your log eg.:
 /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.14.sdk/System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Headers/ATSTypes.h:24:10:
 fatal error: 'CarbonCore/CarbonCore.h' file not found
 > #include <CarbonCore/CarbonCore.h>
 > Does the file exist anywhere on your machine?
 I checked. CarbonCore.h is NOT included in the most recent Mac OSX SDK for
 v. 10.14. However, it IS included in earlier versions, which I have. \\
 /MacOSX10.13.sdk has CarbonCore.h but does not have some other frameworks
 that nviz wants--maybe because Apple dropped default support for OpenGL.
 However, everything needed seems available in /MacOSX10.12.sdk on back,
 which I also have. \\
 In the configure string, I can specify --with-macosx-
 sdk=/Developer/SDKs/MacOSX10.12.sdk. \\
 BUT ctypes appears to ignore this and I get the same error that you
 spotted. It is looking in the default SDK for 10.14 rather than in the one
 I pointed to in configure.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3883#comment:2>
