[GRASS-dev] [GRASS GIS] #3891: t.rast.algebra: if clause with two conditions does not work properly
trac at osgeo.org
Thu Aug 15 05:56:17 PDT 2019
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Temporal | Version: unspecified
Keywords: t.rast.algebra, r.mapcalc | CPU: Unspecified
Platform: Unspecified |
I have a daily lst time series that I converted to celsius degrees. I want
to count how many days per year have LST >= 20 and <= 30. So, I first do
the following:
t.rast.algebra expression="tmean_higher20_lower30 = if(lst_daily_celsius
>= 20.0 && lst_daily_celsius <= 30.0, lst_daily_celsius, null())"
basename=tmean_higher20_lower30 suffix=gran nprocs=7
with the intention of using t.rast.aggregate afterwards.
However, without any error, the `t.rast.algebra` command produces either
an empty STRDS or one full of null maps if I use the -n flag.
If I run the corresponding `r.mapcalc` command for a single date, it works
as expected. Region is properly set, input maps have values in the proper
range. No idea what's wrong. I have used this command before and it worked
just fine. It is indeed something very simple for t.rast.algebra.
The only odd thing I see when I do a dry run is how it builds the
r.mapcalc command, that in the second part of the condition it puts
parenthesis, but I don't know much python as to judge that.
['EQUAL'] False False False True && & False False False
lst_2014_01_01 at italy_LST_1km_daily_reconstructed_daily >=
20.0&&(lst_2014_01_01 at italy_LST_1km_daily_reconstructed_daily <= 30.0)
lst_2014_01_02 at italy_LST_1km_daily_reconstructed_daily >=
20.0&&(lst_2014_01_02 at italy_LST_1km_daily_reconstructed_daily <= 30.0)
[rest skipped]
lst_2018_12_31 at italy_LST_1km_daily_reconstructed_daily >=
20.0&&(lst_2018_12_31 at italy_LST_1km_daily_reconstructed_daily <= 30.0)
build_condition_cmd_list ['EQUAL']
['EQUAL'] False False False False None None False False False
{'STDS': {'name': 'tmean_higher20_lower30',
'stdstype': 'strds',
'temporal_type': 'absolute'},
'processes': [{'flags': ['overwrite'],
'inputs': [('expression',
'tmean_higher20_lower30_2014_01_01=if(lst_2014_01_01 at italy_LST_1km_daily_reconstructed_daily
'20.0&&(lst_2014_01_01 at italy_LST_1km_daily_reconstructed_daily '
'<= 30.0), '
'lst_2014_01_01 at italy_LST_1km_daily_reconstructed_daily, '
'null())'),
('region', 'current')],
'name': 'r.mapcalc',
'outputs': []},
[rest skipped]
'register': [('tmean_higher20_lower30_2014_01_01',
'2014-01-01 00:00:00',
'2014-01-02 00:00:00'),
('tmean_higher20_lower30_2014_01_02',
'2014-01-02 00:00:00',
'2014-01-03 00:00:00'),
[rest skipped]
('tmean_higher20_lower30_2018_12_31',
'2018-12-31 00:00:00',
'2019-01-01 00:00:00')],
'remove': []}
I attach the full output of the dry run.
I tested with python2 and python3, same behavior. I use grass-dev in
Fedora 30.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3891>
