[GRASS-dev] [GRASS GIS] #3891: t.rast.algebra: if clause with two conditions does not work properly
trac at osgeo.org
Thu Aug 15 06:18:59 PDT 2019
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Temporal | Version: unspecified
Resolution: | Keywords: t.rast.algebra, r.mapcalc
CPU: Unspecified | Platform: Unspecified
Comment (by veroandreo):
Ok, this is odd... If I replace the former command, with the following:
t.rast.algebra -n expression="tmean_higher20_lower30 =
if(lst_daily_celsius >= 20.0 && lst_daily_celsius <= 30.0, 1, null())"
basename=tmean_higher20_lower30 suffix=gran nprocs=7 --o
i.e., putting 1 instead of leaving the value that the map has, all works
fine... why does it fail to keep the value that was there originally if it
meets the condition???
Ticket URL: <https://trac.osgeo.org/grass/ticket/3891#comment:2>
