[GRASS-dev] [GRASS GIS] #3885: wxGUI no longer shows start image
trac at osgeo.org
Mon Aug 19 06:07:31 PDT 2019
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: wxGUI | Version:
Resolution: | Keywords: g.gui
CPU: Unspecified | Platform: Unspecified
Description changed by neteler:
Old description:
> When starting `g.gui` in G78dev only a kind of empty frame is shown
> (really, some graphic memory garbage of the window behind if present)
> while it works ok in master.
New description:
System description:
System Info
GRASS version: 7.8.dev
Code revision: a50165153
Build date: 2019-08-12
Build platform: x86_64-pc-linux-gnu
GDAL: 2.3.2
PROJ.4: 5.2.0
GEOS: 3.7.1
SQLite: 3.26.0
Python: 3.7.4
wxPython: 4.0.4
Platform: Linux-5.2.8-200.fc30.x86_64-x86_64-with-fedora-30-Thirty
Ticket URL: <https://trac.osgeo.org/grass/ticket/3885#comment:6>
