[GRASS-dev] Fwd: Re: [OSGeoLive] #2181: GRASS freezes when using r.import on file without projection
Markus Neteler neteler at osgeo.org
Sat Aug 31 23:35:16 PDT 2019
*Von:* OSGeoLive <trac_osgeolive at osgeo.org>
*Gesendet:* 31. August 2019 17:38:31 OESZ
*Betreff:* Re: [OSGeoLive] #2181: GRASS freezes when using r.import on file
without projection
 Reporter:  johanvdw   |       Owner:  osgeolive@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  OSGeoLive13.0
Component:  OSGeoLive  |  Resolution:
 Keywords:  grass      |
Changes (by kalxas):
 * keywords:   => grass
 * cc: osgeolive@… (added)
 * priority:  minor => major
 * type:  task => defect
 * milestone:   => OSGeoLive13.0
Ticket URL: <https://trac.osgeo.org/osgeolive/ticket/2181#comment:3>
OSGeoLive <http://live.osgeo.org/>
self-contained bootable DVD, USB thumb drive or Virtual Machine based
on Lubuntu, that allows you to try a wide variety of open source
geospatial software without installing anything.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190901/e1aca996/attachment.html>
