[GRASS-dev] [GRASS GIS] #3981: winGRASS: defining a new location by EPSG code: TypeError: invalid result from TransList.OnMeasureItem(), an integer is required (got type NoneType)
Zoltan Szecsei
zoltans at geograph.co.za
Tue Dec 3 06:47:34 PST 2019
I think I am banging my head on this error #3981
I posted my problem to grass-user, but no response.
Is there a possible workaround for me?
Thanks,
Zoltan.
On 2019/12/02 11:49, Zoltan Szecsei wrote:
> Hi,
> I'm using EPSG 2932 and QGIS etc all are OK with it.
> I have installed everything using OSGeo4W64, so how come Grass does
> not use the same projections database (as QGis etc)?
> (and please can I have a pointer as to how to introduce EPSG 2932 to
> Grass 7.8.1)
> Thanks and regards,
> Zoltan
> ******** Running against:
> D:\GDBroad_tiles\shp_road_poly_few\23103770_road_poly.shp
> WARNING: Datum <Qatar_National_Datum_1995> not recognised by GRASS and
> no parameters found
> Check if OGR layer <23103770_road_poly> contains polygons...
> Creating attribute table for layer <23103770_road_poly>...
> WARNING: Name <23103770_road_poly> is not SQL compliant. Must start
> with a letter.
> Importing 28 features (OGR layer <23103770_road_poly>)...
> Reporter: hellik | Owner: grass-dev@…
> Type: defect | Status: new
> Priority: normal | Milestone: 7.8.2
> Component: wxGUI | Version: git-releasebranch78
> Resolution: | Keywords: wingrass, py3, python3, proj6
> CPU: x86-64 | Platform: MSWindows
> Comment (by annakrat):
> https://github.com/OSGeo/grass/pull/233
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
Zoltan Szecsei GPrGISc 0031
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028 (WhatsApp only)
Qatar: +974 5083 2722 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191203/45ed2978/attachment-0001.html>
