[GRASS-dev] [GRASS GIS] #4005: i.sentinel.mask: use raster based approach for shadow detection
GRASS GIS trac at osgeo.org
Wed Dec 4 02:20:17 PST 2019
 Reporter:  sbl              |      Owner:  grass-dev@…
     Type:  enhancement      |     Status:  new
 Priority:  normal           |  Milestone:
Component:  Addons           |    Version:  unspecified
 Keywords:  i.sentinel.mask  |        CPU:  Unspecified
 Platform:  Unspecified      |
 Detection of cloud shadows can be quite time consuming at times, esp. with
 many clouds and shadows in an image.
 The performance of the process could be improved by orders of magnitude,
 if a raster based approach (r.reclass.area + r.region + r.stats) would be
 used, instead of going through vector data (r.to.vect + v.clean +
 v.transform + v.to.db).
 In most cases, a raster mask is needed anyway in the processing chain
 downstreams...
Ticket URL: <https://trac.osgeo.org/grass/ticket/4005>
