[GRASS-dev] [GRASS GIS] #3959: Interface needs to warn that directory must be created before start
trac at osgeo.org
Fri Dec 6 12:33:40 PST 2019
Reporter: jidanni | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: trivial | Milestone:
Component: Startup | Version: unspecified
Resolution: | Keywords: init grass.py default
CPU: Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* keywords: => init grass.py default
Comment:
I also prefer if the situation is resolved automatically in general, but
I'm not sure if that should be the case in command line startup. The
message should suggest next steps, but creating a directory where all
user's data is stored (not just some temporary dump directory) might be
little too much initiative taken by a command line program because user
may expect better control.
When you start GUI, it does create this directory by default, but it will
in the future. That's however different from command line I think.
Therefore, I'm for improving the message (perhaps even explaining the
purpose of that directory better) but not changing the behavior.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3959#comment:1>
