[GRASS-dev] [GRASS GIS] #3967: Add batch job example without path
trac at osgeo.org
Fri Dec 6 13:29:51 PST 2019
Reporter: jidanni | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: trivial | Milestone:
Component: Docs | Version: unspecified
Resolution: | Keywords: grass.py exec CLI init
CPU: Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* keywords: => grass.py exec CLI init
Comment:
Actually, I did not include it into documentation intentionally, but did
not disable it - a dirty trick. I don't know if it is a good idea to do
this, but it might be useful for some. Generally speaking, why would you
like to run a batch job with whatever was the last used mapset? Of course,
`--exec` is meant to be used more broadly than just batch jobs, but still
it seems to me that specifying full path is appropriate.
If you would be using GRASS GIS only with `--exec`, this may not work as
expected because `--exec` actually does not save the path (to a file in
`~/.grass7`), so the next call is using path from an interactive session
(in GUI or with `--text`).
What you can do now is a workflow like this:
grass grassdata/location/mapset -c EPSG:3358 -e
grass grassdata/location/mapset --exec r.import input=some_image.tif
output=some_image
grass grassdata/location/mapset --exec r.info some_image
grass grassdata/location/mapset --exec r.mapcalc "improved_image = 5 *
some_image"
grass grassdata/location/mapset --exec r.out.gdal input=improved_image
output=.../improved_image.tiff
I think you are suggesting you want a workflow like this:
grass --exec r.import input=some_image.tif output=some_image
grass --exec r.info some_image
grass --exec r.mapcalc "improved_image = 5 * some_image"
grass --exec r.out.gdal input=improved_image
It seemed to be that `--exec` probably should not behave like that, so
e.g. in #2579 (under Additional ideas), I suggested a subcommand
directory-oriented interface using a hidden file in the current directory
(but which still keeps the "connect to any grassdata/location/mapset"
concept):
grass init grassdata/location/mapset EPSG:3358
grass lock grassdata/location/mapset
grass exec r.import input=some_image.tif output=some_image
grass exec r.info some_image
grass exec r.mapcalc "improved_image = 5 * some_image"
grass exec r.out.gdal input=improved_image output=improved_image.tif
grass unlock
(The above is just an idea for now, init and lock could be merged,
grassdata/location/mapset could default to something in init and use more
//convention over configuration// in lock, unlock could be renamed...)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3967#comment:1>
