[GRASS-dev] [GRASS GIS] #4009: 'where' option in v.to.rast can select wrong feature for raster attribute, in areas where features overlap
trac at osgeo.org
Fri Dec 13 01:07:02 PST 2019
Reporter: florisvdh | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: svn-releasebranch76
Resolution: | Keywords: v.to.rast sql where
CPU: x86-64 | Platform: Linux
Comment (by florisvdh):
Below are a few characteristics of the map. Note, the actual values of
{{{field 1}}} are not 'x1', 'x2' etc. but specific codes. Given the size
of the data, I truncated the output.
$ v.info polygon_layer -c
Displaying column types/names for database connection of layer <1>:
INTEGER|cat
TEXT|field1
DOUBLE PRECISION|field2
$ v.db.select map=polygon_layer | wc -l
85051
$ v.db.select map=polygon_layer where="field1 LIKE 'rbbhc'" | wc -l
4720
$ v.db.select map=polygon_layer where="field1 LIKE 'rbbhc'" | head
cat|field1|field2
132|rbbhc|20
146|rbbhc|70
151|rbbhc|30
152|rbbhc|30
153|rbbhc|30
154|rbbhc|30
155|rbbhc|30
156|rbbhc|30
157|rbbhc|30
Ticket URL: <https://trac.osgeo.org/grass/ticket/4009#comment:2>
