[GRASS-dev] [GRASS GIS] #3582: Removing a Mapset from inside a GRASS GIS session
    trac at osgeo.org
    Sun Dec 15 12:26:13 PST 2019
  Reporter:  Nikos Alexandris  |      Owner:  grass-dev@…
      Type:  enhancement       |     Status:  new
  Priority:  normal            |  Milestone:  7.8.3
 Component:  Default           |    Version:  unspecified
Resolution:                    |   Keywords:  mapset, remove, delete, erase
       CPU:  Unspecified       |   Platform:  Unspecified
Comment (by neteler):
 Replying to [comment:1 jidanni]:
 > And mentioned on grass7.html, which tells one how to create them from
 > the command line, but forgets to then add how to remove them!
 If you can, please suggest an edit (PR) here:
 https://github.com/OSGeo/grass/blob/master/lib/init/grass7.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3582#comment:3>
