[GRASS-dev] [GRASS GIS] #3742: t.rast.aggregate: allow multiple methods/output
GRASS GIS trac at osgeo.org
Sat Feb 2 14:53:00 PST 2019
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.8.0
 Component:  Temporal     |    Version:  svn-trunk
Resolution:               |   Keywords:  t.rast.aggregate
       CPU:  All          |   Platform:  All
Comment (by sbl):
 Please find attached a patch with a first attempt to allow for multiple
 methods (and thus output) in t.rast.aggregate. Testing is very welcome!
 Unfortunately, I forgot to use your patch, Markus. Will update ASAP.
 It is implemented as outlined above, where current behavior with regards
 to map names is kept, if only one method is requested. If however multiple
 methods are requested, the method name is injected between basename and
 suffix.
 The patch also fixes one test for the temporal framework, which partly was
 due to quoting that was introduced for t.info... (Maybe a different
 ticket)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3742#comment:4>
