[GRASS-dev] ZSTD compressor not compiled by default if available
Nikos Alexandris nik at nikosalexandris.net
Mon Feb 4 05:20:47 PST 2019
Dears,
do I understand it wrong that, if available in a system, the ZSTD
compressor _should_ be compiled by default?  Or does the choice for
"default" concern only the `r.compress` module?
In trunk:
./configure --help |grep zstd
  --with-zstd             support Zstandard functionality (default: no)
  --with-zstd-includes=DIRS
  --with-zstd-libs=DIRS   ZSTD library files are in DIRS
Thank you, Nikos
