[GRASS-dev] [GRASS GIS] #3746: Quouting of strings with white space in t.info breaks tests for temporal modules
GRASS GIS trac at osgeo.org
Mon Feb 4 13:56:02 PST 2019
modules
  Reporter:  sbl     |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  normal  |  Milestone:  7.8.0
 Component:  Tests   |    Version:  svn-trunk
Resolution:          |   Keywords:  temporal,t.info
       CPU:  All     |   Platform:  All
Comment (by sbl):
 Relevant files:
 temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
 temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
 temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
 temporal/t.info/testsuite/test.t.info.sh
 temporal/t.merge/testsuite/test.t.merge.sh
 temporal/t.rast3d.extract/testsuite/test_extract.py
 temporal/t.rast3d.extract/testsuite/test.t.rast3d.extract.sh
 temporal/t.rast.accdetect/testsuite/test_simple.py
 temporal/t.rast.aggregate.ds/testsuite/test.t.rast.aggregate.ds.sh
 temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py
 temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
 temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py
 temporal/t.rast.contour/testsuite/test_convert.py
 temporal/t.rast.extract/testsuite/test_extract.py
 temporal/t.rast.gapfill/testsuite/test_gapfill.py
 temporal/t.rast.import/testsuite/test_temporal_rast_import.py
 temporal/t.rast.series/testsuite/test_series.py
 temporal/t.rast.to.vect/testsuite/test_to_vect.py
 temporal/t.vect.extract/testsuite/test_vect_extract.py
 temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh
 temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh
 temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh
Ticket URL: <https://trac.osgeo.org/grass/ticket/3746#comment:1>
