[GRASS-dev] [GRASS GIS] #3746: Quouting of strings with white space in t.info breaks tests for temporal modules
GRASS GIS trac at osgeo.org
Sat Feb 9 13:54:37 PST 2019
modules
  Reporter:  sbl     |      Owner:  grass-dev@…
      Type:  defect  |     Status:  closed
  Priority:  normal  |  Milestone:  7.8.0
 Component:  Tests   |    Version:  svn-trunk
Resolution:  fixed   |   Keywords:  temporal,t.info
       CPU:  All     |   Platform:  All
Changes (by sbl):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 The rest of the test-errors in the temporal testsuites were not touched as
 they indicate other issues (e.g. related to Python 3, changed results, or
 errors in the test-code.)
 Types of those errors are:
 * AssertionError: reference argument is not a string (in several tests)
 * grass.exceptions.FatalError: Wrong type of input A (in algebra tests)
 * AttributeError: 'NoneType' object has no attribute 'second' (in several
 tests related to datetime_math)
 * AssertionError: There is no map <b_2001_01_01_00> of type <raster> in
 the current mapset (t.rast.aggregate)
 * Process ended with non-zero return code t.remove(inputs=['R'],
 type='strds', flags=u'rf', quiet=True). See errors in the (error) output.
 * UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
 position 2: ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3746#comment:6>
