[GRASS-dev] [GRASS GIS] #3226: v.select: how to handle situation where no features are found
trac at osgeo.org
Sat Feb 9 18:25:00 PST 2019
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.2.4
Component: Vector | Version: svn-trunk
Resolution: fixed | Keywords: v.select
CPU: Unspecified | Platform: Unspecified
Comment (by hcho):
I'm not sure if "not" creating an empty vector is more efficient. For
example,
v.select ainput=vect1 binput=vect2 output=outvect operator=disjoint --o
# the existence and validity of outvect would be guaranteed if v.select
created
# an empty output for no features
for cat in `v.db.select -c map=outvect column=cat`; do
echo $cat
done
needs to be changed like this:
# make sure there is no previous output vector because v.select won't
# delete or create a new empty vector when no features are selected
g.remove -f type=vector name=outvect
# check if v.select selected any features
eval `g.findfile element=vector file=outvect`
if [ "x$file" != "x" ]; then
echo $cat
done
fi
I think "at least" this module should delete the output vector if no
features are selected with --o flag to avoid a false positive "by mistake"
and save one line, but for me, it makes more sense to create an empty
output for easier scripting. Maybe a new flag like -e for empty output?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3226#comment:14>
