[GRASS-dev] Fwd: Memory consumption using pygrass.utils.get_raster_for_points
Steven Pawley
dr.stevenpawley at gmail.com
Wed Feb 13 13:03:35 PST 2019
As a follow-up to this, I tried tracking the memory usage using the python
Pympler package.
I ran the following code block:
from grass.pygrass.vector import VectorTopo
from grass.pygrass.raster import RasterRow
from grass.pygrass.modules.shortcuts import raster as r
from grass.pygrass.gis.region import Region
from grass.pygrass.utils import get_raster_for_points
# set region
reg = Region()
reg.from_rast("landclass96")
reg.write()
reg.set_raster_region()
# generate a large point dataset
r.random(input="landclass96", npoints=200000, vector="landclass96_roi",
overwrite=True)
# memory tracking
from pympler.tracker import SummaryTracker
tracker = SummaryTracker()
points = VectorTopo("landclass96_roi")
points.open("r")
# repeat spatial query of raster
for i in range(10):
print(i)
with RasterRow("lsat5_1987_10") as src:
arr = get_raster_for_points(points, src)
points.close()
tracker.print_diff()
The memory tracker results are:
types | # objects
| total size
<class 'grass.pygrass.raster.buffer.Buffer | 2000000
| 4.16 GB
dict | 6000022
| 1.56 GB
<class 'grass.lib.ctypes_preamble.LP_c_int | 2000000
| 274.66 MB
<class 'ctypes.c_void_p | 2000000
| 274.66 MB
<class 'numpy.core._internal.c_char_Array_0 | 2000000
| 274.66 MB
<class 'numpy.core._internal.LP_c_char_Array_0 | 2000000
| 274.66 MB
numpy.ndarray | 2000000
| 152.59 MB
<class 'numpy.core._internal._unsafe_first_element_pointer | 2000000
| 122.07 MB
int | 4001700
| 91.59 MB
list | 14032
| 2.99 MB
str | 14072
| 845.98 KB
StgDict | 2
| 1.20 KB
weakref | 12
| 1.03 KB
_ctypes.PyCPointerType | 1
| 904 B
_ctypes.PyCArrayType | 1
So, grass.pygrass.raster.buffer.Buffer is still using 4.16 GB despite the
RasterRow object being closed, and that there are 200,000 of those objects
remaining in memory, which I think means that for each of my 200,000
points, the Buffer object which contains a row from the RasterRow object
for each point coordinate has remained in memory. There is also a dict that
is consuming memory as well, and I can see that the
grass.pygrass.raster.raster_type module, called by Buffer, uses a dict to
store the cell type of the Buffer.
Steve
---------- Forwarded message ---------
Date: Sat, Feb 9, 2019 at 9:48 AM
Subject: Memory consumption using pygrass.utils.get_raster_for_points
To: GRASS developers list <grass-dev at lists.osgeo.org>
Hello devs,
When running pygrass.utils.get_raster_for_points repeatedly, it appears
that the python memory allocation continuously increases until all ram is
consumed, even if the extracted values are not being collected (or are
overwriting the same variable).
I noticed this when extracting raster data at point locations, when using a
large point dataset, even though I had pre-allocated a numpy array to
receive the results.
Below is an example on the nc_spm_08_grass7 example data (in the landsat
mapset), repeating the operation say 50 times on the same point vector
dataset. I wouldn't have expected the memory consumption to continuously
increase for this operation, because I'm overwriting the 'arr' variable
each time. However, if you repeat this enough times, you will run out of
system memory and the allocated memory does not appear to be released, i.e.
even if you manually force garbage collection.
Any suggestions?
reg = Region()
reg.write()
overwrite=True)
points.open("r")
for i in range(50):
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190213/03e9a8a4/attachment.html>
