[GRASS-dev] [GRASS GIS] #3752: g.gui.animation: TypeError: 'zip' object is not subscriptable
GRASS GIS trac at osgeo.org
Fri Feb 15 11:39:25 PST 2019
 Reporter:  veroandreo         |      Owner:  grass-dev@…
     Type:  defect             |     Status:  new
 Priority:  normal             |  Milestone:  7.8.0
Component:  wxGUI              |    Version:  svn-trunk
 Keywords:  temporal, python3  |        CPU:  Unspecified
 Platform:  Linux              |
 I encountered the error in the subject when running under python3
 virtualenv:
 g.gui.animation strds=A
   File "/usr/lib64/python3.7/site-packages/wx/core.py", line 3190, in
 <lambda>
     lambda event: event.callable(*event.args, **event.kw) )
   File "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-
 gnu/gui/wxpython/animation/frame.py", line 196, in SetAnimations
     self.controller.SetAnimations(layerLists)
 gnu/gui/wxpython/animation/controller.py", line 305, in SetAnimations
     self._setAnimations()
 gnu/gui/wxpython/animation/controller.py", line 326, in _setAnimations
     mapNamesDict=mapNamesDict)
 gnu/gui/wxpython/animation/controller.py", line 375, in _updateAnimations
     anim.firstStdsNameType[0]], regions)
 gnu/gui/wxpython/animation/utils.py", line 358, in
 sampleCmdMatrixAndCreateNames
     namesList.append(HashCmds(cmdMatrix[j], regions[j]))
 WARNING:root:Needed to restart the libgis server, caller: Server check
 thread
 To reproduce in NC location:
 g.region raster=elevation
 for map in `seq 1 10` ; do r.mapcalc "prueba_${map} = ${map}" ; done
 t.create output=A type=strds temporaltype=absolute title="test"
 description="test"
 t.register input=A maps=`g.list rast pat=prueba* sep=, map=.`
 start="2000-01-01" increment="1 months" -i
Ticket URL: <https://trac.osgeo.org/grass/ticket/3752>
