[GRASS-dev] [GRASS GIS] #3758: zstd-suport in GRASS >= 7.6: update manuals for variables and r.compress
GRASS GIS trac at osgeo.org
Thu Feb 21 01:15:17 PST 2019
  Reporter:  sbl     |      Owner:  grass-dev@…
      Type:  defect  |     Status:  new
  Priority:  normal  |  Milestone:  7.6.1
 Component:  Docs    |    Version:  svn-releasebranch76
Resolution:          |   Keywords:  r.compress,variables
       CPU:  All     |   Platform:  All
Comment (by sbl):
 Thanks. Found one little glitch (see attached diff for a suggestion).
 BTW., the manual for r.compress
 (https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.compress/r.compress.html?rev=74114#L98)
 says:
 The NULL file compression is using the LZ4 method as being the best
 compromise between speed and compression rate.
 Is that still accurate?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3758#comment:3>
