[GRASS-dev] [GRASS GIS] #3486: v.in.ogr/v.out.ogr: default format in online manual
trac at osgeo.org
Thu Feb 21 01:50:32 PST 2019
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.4.5
Component: Docs | Version: unspecified
Resolution: | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:19 Sylvain POULAIN]:
> Problem is about wxgui sorry for this misunderstanding !
> With v.in.ogr, GPKG is not present in file listing but is present in
directory (I didn't notice that until today). Even with that, you could
not select gpkg from file with the GUI ("v.in.ogr -f | grep GPKG" is ok !)
> With r.out.gdal, it's not present in the list but could be changed
manually. ("r.out.gdal -l | grep GPKG" is ok !
> But Idea is : some promotes gpkg but it's not totally support in Grass
Gui (r.in.gdal is ok)
I see. Changed in trunk r74122, the GUI knows now about GeoPackages.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3486#comment:20>
