[GRASS-dev] [GRASS GIS] #3756: r.watershed: flow accumulation wrong with edge contamination
trac at osgeo.org
Thu Feb 21 02:41:20 PST 2019
Reporter: itati01 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: svn-releasebranch76
Resolution: | Keywords: r.watershed, flow accumulation,
CPU: | edge contamination
Unspecified | Platform: Unspecified
Comment (by itati01):
Your first answer explained already everything. Thank you very much for
this exhaustive explanation. I had assumed that negative values are also
cumulated. So, I will close this ticket and have to find some other way
without setting channel cells to nodata.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3756#comment:4>
