[GRASS-dev] [GRASS GIS] #3179: g.extension not installing addons behind proxy
trac at osgeo.org
Fri Feb 22 07:09:02 PST 2019
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.5
Component: Addons | Version: unspecified
Resolution: | Keywords: g.extension, proxy, addons
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:13 mlennert]:
> Replying to [comment:12 neteler]:
> > Replying to [comment:11 mmetz]:
> > > Replying to [comment:10 neteler]:
> > > > Fix attempt via https://github.com/GRASS-GIS/grass-ci/pull/6
submitted as r74116.
> > > > Note the different proxy syntax in the manual page.
> > > > If ok, to be backported.
> > > Note, this is introducing a new python dependency, on RHEL 7 and
derivates, this is python-requests.
> > Yes, I realized that today.
> > > Do we have a list of required python 2 components and required
python 3 components that can be updated?
> > Also yes. See r74121, it is REQUIREMENTS.html.
> > > Ideally such a list would also indicate which python components are
required only for the GUI (systems such as HPC may use GRASS without GUI).
> > That's more or less indicated in that file.
> > So, I am undecided now about the backport.
> I would plead for reworking this to use urllib2 (Python 2) which is
already imported in the module and which seems to work according to madi.
+1
> Let's try to avoid the endless dependency hell just out of easy
availability of small helper packages. See the [https://hackernoon.com
/whats-really-wrong-with-node-modules-and-why-this-is-your-fault-
8ac9fa893823 experience] with npm in the Javascript world as a case in
point. I would plead to keep most modules down to standard python library
dependency, unless there really is no other way.
+1
Ticket URL: <https://trac.osgeo.org/grass/ticket/3179#comment:14>
