[GRASS-dev] Fwd: [PROJ] PROJ 6RC2
Sebastiaan Couwenberg sebastic at xs4all.nl
Sat Feb 23 08:17:01 PST 2019
On 2/23/19 3:59 PM, Markus Neteler wrote:
> there is some discussion about packages that need to be patched to use
> proj_api.h or proj.h which will no longer be available in recent PROJ.
To clarify, the discussion is about patching packages that use
projects.h which is no longer available in PROJ 6.
As announced with the release of PROJ 5, project should use proj_api.h
or proj.h.
GRASS now uses proj_api.h which will remain available until PROJ 7, see:
 https://github.com/OSGeo/proj.4/milestones
> Is there anything to do in GRASS GIS (trunk)?
Work could be started on supporting the new proj.h API.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
