[GRASS-dev] [GRASS GIS] #3759: Grass V.Krige/v.kriging add on install missing libraries
GRASS GIS trac at osgeo.org
Sat Feb 23 13:13:57 PST 2019
 Reporter:  fanfanchart  |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.6.1
Component:  Default      |    Version:  unspecified
 Keywords:               |        CPU:  Unspecified
 Platform:  Unspecified  |
 When installing the add on v.krige and running it, the error message (see
 below) indicates that
 https://grass.osgeo.org/grass74/manuals/addons/
 --> Windows log files
     --> vector/v.kriging FAILED log
 http://wingrass.fsv.cvut.cz/grass74/x86/addons/latest/logs/v.kriging.log
 " #error GRASS GIS is not configured with BLAS (la.h cannot be included)
 This means that the LAPACK/BLAS numerical libraries are apparently not
 installed/activated on the wingrass server on which the WinGRASS
 addons are built.
 see below:
 https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_7_4/mswindows/osgeo4w/package.sh#L168
 for the compilation configuration of winGRASS:
 168             LDFLAGS="-L$PWD/mswindows/osgeo4w/lib -lz" ./configure \
 169                     --host=$conf_host \
 170                     --with-libs="$PWD/mswindows/osgeo4w/lib "\
 171                     --with-includes=$OSGEO4W_ROOT_MSYS/include \
 172                     --libexecdir=$OSGEO4W_ROOT_MSYS/bin \
 173                     --prefix=$OSGEO4W_ROOT_MSYS/apps/grass \
 174                     --bindir=$OSGEO4W_ROOT_MSYS/bin \
 175                     --includedir=$OSGEO4W_ROOT_MSYS/include \
 176                     --without-x \
 177                     --with-cxx \
 178                     --enable-shared \
 179                     --enable-largefile \
 180                     --with-fftw \
 181                     --with-freetype \
 182                     --with-proj-share=$OSGEO4W_ROOT_MSYS/share/proj \
 183                     --with-gdal=$PWD/mswindows/osgeo4w/gdal-config \
 184                     --with-geos=$PWD/mswindows/osgeo4w/geos-config \
 185                     --with-sqlite \
 186                     --with-regex \
 187                     --with-nls \
 188
 --with-freetype-includes=$OSGEO4W_ROOT_MSYS/include/freetype2 \
 189                     --with-odbc \
 190                     --with-cairo \
 191                     --with-postgres \
 192                     --with-opengl=windows \
 193                     --with-bzlib $conf_opts
 and see addon compilation log:
 (https://wingrass.fsv.cvut.cz/grass77/x86_64/addons/grass-7.7.svn/logs/v.kriging.log)
 "C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/la.h:17:2:
 error: #error GRASS GIS is not configured with BLAS (la.h cannot be
 included)
 C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/la.h:21:2:
 error: #error GRASS GIS is not configured with LAPACK (la.h cannot be
 included)
  #error GRASS GIS is not configured with LAPACK (la.h cannot be included)
 In file included from geostat.c:1:0:
 local_proto.h:24:2: warning: #warning G_matrix_product() not compiled;
 requires GRASS GIS compiled and installed with BLAS library support
 [-Wcpp]
  #warning G_matrix_product() not compiled; requires GRASS GIS compiled and
 installed with BLAS library support"
 open an enhancement ticket to include BLAS into winGRASS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3759>
