[GRASS-dev] [GRASS GIS] #3761: Verbosity of g.extension when using the -f flag
GRASS GIS trac at osgeo.org
Mon Feb 25 00:32:58 PST 2019
 Reporter:  Nikos Alexandris  |      Owner:  grass-dev@…
     Type:  defect            |     Status:  new
 Priority:  normal            |  Milestone:
Component:  Addons            |    Version:  unspecified
 Keywords:  g.extension       |        CPU:  Unspecified
 Platform:  Unspecified       |
 In `g.extension`, in the `def remove_extension()` function, there is:
     if force:
         grass.verbose(_("List of removed files:"))
     else:
         grass.info(_("Files to be removed:"))
 and
     if force:
         grass.message(_("Updating addons metadata file..."))
         remove_extension_xml(mlist)
         grass.message(_("Extension <%s> successfully uninstalled.") %
                       options['extension'])
 This is not correct in my humble view.  In case of using the `-f` flag,
 the messages will be emitted regardless of any successful or non-
 successful execution of the `remove_extension_xml` function which in turn
 can be misleading.
 I suggest these messages to be integrated in the functions for which they
 report whatever they report. I have no solution to propose yet, but this
 ticket serves to highlight the problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3761>
