[GRASS-dev] GRASS GIS + PROJ 6 + GDAL 2.5
Martin Landa landa.martin at gmail.com
Mon Feb 25 06:29:02 PST 2019
po 25. 2. 2019 v 15:10 odesílatel Markus Metz
<markus.metz.giswork at gmail.com> napsal:
> GRASS needs some adjustments in order to be compatible with PROJ 6 + GDAL 2.5
> The plain text file "share/proj/epsg" no longer exists. This file is currently required by the GUI location wizard to retrieve a list of known EPSG codes. Now there is a sqlite db "proj.db", and a new PROJ function proj_get_codes_from_database(). I suggest to enhance g.proj with a new option "list_codes_auth" which will print a list of codes for the given autority name (EPSG, IGNF, etc.). This option can be made backwards compatible to read "share/proj/epsg" with PROJ versions up to 5. The location wizard can then use this new output of g.proj to construct a list of known EPSG codes.
sounds like a good plan :-) Worth to create new enhancement ticket? Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
