[GRASS-dev] error when compiling grass with pdal
Paulo van Breugel p.vanbreugel at gmail.com
Wed Jan 2 05:58:45 PST 2019
Hi devs,
I am trying to compile grass with pdal. My system is Ubuntu 18.04, grass
7.7.svn (r73901), pdal 1.8.0 (git-version: dfface).
When trying to compile with
--with-pdal=/usr/local/bin/pdal-config
I get the following error message:
Errors in:
/home/paulo/Software/Linux/grass7/trunk/vector/v.in.pdal
When running make in the v.in.pdal folder, I get:
make
if [ "/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin/v.in.pdal" != "" ] ; then GISRC=/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/demolocation/.grassrc77 GISBASE=/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu PATH="/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/etc/python:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/scripts:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/lib:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/lib:" LC_ALL=C LANG=C LANGUAGE=C /home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin/v.in.pdal --html-description < /dev/null | grep -v '</body>\|</html>' > v.in.pdal.tmp.html ; fi
/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin/v.in.pdal: error while loading shared libraries: libpdal_base.so.7: cannot open shared object file: No such file or directory
../../include/Make/Html.make:14: recipe for target 'v.in.pdal.tmp.html' failed
make: *** [v.in.pdal.tmp.html] Error 1
rm v.in.pdal.tmp.html
Any idea what I am doing wrong?
Cheers,
Paulo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190102/49c5fc9a/attachment.html>
