[GRASS-dev] [GRASS GIS] #3723: winGRASS7.7.svn - core.py - python 3 issues
trac at osgeo.org
Sat Jan 5 12:12:46 PST 2019
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.8.0
Component: Python | Version: svn-trunk
Resolution: | Keywords: python3, py3, wingrass
CPU: Unspecified | Platform: MSWindows
Comment (by hellik):
Replying to [comment:6 hellik]:
> if any(cmd.lower().endswith(ext.lower()) for ext in pathext):
> File
"C:\OSGeo4W\apps\grass\grass-7.7.svn\etc\python\grass\script\core.py", li
> ne 220, in <genexpr>
> TypeError: endswith first arg must be bytes or a tuple of bytes, not str
now also tested with the OSGeo4W 64bit version.
C:\>g.version -g
version=7.7.svn
date=2019
revision=r73906
build_date=2019-01-04
build_platform=x86_64-w64-mingw32
build_off_t_size=8
same error
C:\>g.gui wxpython
Launching <wxpython> GUI in the background, please wait...
File "C:\OSGEO4~1\apps\grass\grass-7.7.svn/gui/wxpython/wxgui.py", line
27, in <module>
from core import globalvar
File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\core\globalvar.py",
line 31, in <module>
from core.debug import Debug
File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\core\debug.py",
line 77, in <module>
Debug = DebugMsg()
line 39, in __init__
self.SetLevel()
line 45, in SetLevel
self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\etc\python\grass\script\core.py",
line 1082, in gisenv
s = read_command("g.gisenv", flags='n', env=env)
File
line 502, in read_command
process = pipe_command(*args, **kwargs)
File
line 471, in pipe_command
return start_command(*args, **kwargs)
File
line 396, in start_command
if debug_level() > 0:
File
line 1670, in debug_level
_debug_level = int(gisenv().get('DEBUG', 0))
File
File
File
File
line 401, in start_command
return Popen(args, **popts)
File
line 66, in __init__
cmd = shutil_which(args[0])
File
line 220, in shutil_which
File
line 220, in <genexpr>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3723#comment:7>
