[GRASS-dev] [GRASS GIS] #3731: winGRASS7.7.svn python3 build issues
trac at osgeo.org
Tue Jan 15 23:16:05 PST 2019
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Python ctypes | Version: svn-trunk
Resolution: | Keywords: wingrass, python3, py3
CPU: Unspecified | Platform: Unspecified
Comment (by martinl):
Build no. 375 fails with new issues
File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\wxgui.py", line
103, in OnInit
workspace=self.workspaceFile)
File "C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\lmgr\frame.py",
line 131, in __init__
self._moduleTreeBuilder =
LayerManagerModuleTree(message_handler=add_menu_error)
File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\lmgr\menudata.py", line
69, in __init__
message_handler=message_handler)
File
"C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\core\menutree.py", line
72, in __init__
xmlTree = etree.parse(filename)
File "C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py", line
1197, in parse
tree.parse(source, parser)
File "C:\OSGEO4~1\apps\Python37\lib\xml\etree\ElementTree.py", line 598,
in parse
self._root = parser._parse_whole(source)
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
Reason:
`C:\OSGEO4~1\apps\grass\grass-7.7.svn\gui\wxpython\xml\module_tree_menudata.xml`
is empty.
Related traceback:
File "core/toolboxes.py", line 914, in <module>
sys.exit(main())
File "core/toolboxes.py", line 898, in main
userDefined=False)
File "core/toolboxes.py", line 307, in createTree
moduleItems=moduleItems)
File "core/toolboxes.py", line 344, in toolboxes2menudata
_expandRuntimeModules(root)
File "core/toolboxes.py", line 645, in _expandRuntimeModules
desc, keywords = _loadMetadata(name)
File "core/toolboxes.py", line 682, in _loadMetadata
task = gtask.parse_interface(module)
File
"C:\msys64\usr\src\grass_trunk\dist.x86_64-w64-mingw32\etc\python\grass\script\task.py",
line 524, in parse_interface
tree = etree.fromstring(get_interface_description(name))
File
line 476, in get_interface_description
stderr=PIPE)
File
"C:\msys64\usr\src\grass_trunk\dist.x86_64-w64-mingw32\etc\python\grass\script\core.py",
line 66, in __init__
cmd = shutil_which(args[0])
File
line 222, in shutil_which
if any(cmd.lower().endswith(ext) for ext in pathext):
File
line 222, in <genexpr>
TypeError: endswith first arg must be str or a tuple of str, not bytes
Makefile:46: recipe for target 'xml/module_tree_menudata.xml' failed
make[4]: *** [xml/module_tree_menudata.xml] Error 1
Seems to be related to r73930 (#3723)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3731#comment:10>
