[GRASS-dev] v.select: increasing memory consumption
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Thu Jan 17 05:11:42 PST 2019
Dear all,
A colleague of mine just experienced that v.select in GRASS 7.4.3 (from UbuntuGIS) did not stop allocating memory until the server (Ubuntu 16.04) almost died and he killed the process.
Is that a bug or would v.select have stopped allocating memory at some point before the system gets unusable? Or is this something the user should take care of? If I remember correctly there is a "LOW_MEM option" for v.in.ogr would such a thing be needed here to.
In a multi-user environment this can be a bit tricky...
Any hints? Should I open a ticket (probably hard to reproduce with small test-dataset)?
Kind regards,
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190117/d2900d29/attachment.html>
