[GRASS-dev] v.select: increasing memory consumption
Markus Metz markus.metz.giswork at gmail.com
Sat Jan 19 13:16:42 PST 2019
On Fri, Jan 18, 2019 at 8:29 AM Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> THanks, we`ll try and report back.
> -----Original Message-----
> From: Markus Neteler <neteler at osgeo.org>
> Sent: fredag 18. januar 2019 07:52
> To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> Cc: GRASS developers list (grass-dev at lists.osgeo.org) <
grass-dev at lists.osgeo.org>
> Subject: Re: [GRASS-dev] v.select: increasing memory consumption
> Hi,
> On Thu, Jan 17, 2019 at 2:11 PM Stefan Blumentrath <
> > Dear all,
> > A colleague of mine just experienced that v.select in GRASS 7.4.3 (from
UbuntuGIS) did not stop allocating memory until the server (Ubuntu 16.04)
almost died and he killed the process.
> > Is that a bug or would v.select have stopped allocating memory at some
point before the system gets unusable? Or is this something the user should
take care of? If I remember correctly there is a “LOW_MEM option” for
v.in.ogr would such a thing be needed here to.
> > In a multi-user environment this can be a bit tricky…
> yeah!
> > Any hints? Should I open a ticket (probably hard to reproduce with
small test-dataset)?
> Please re-run the job with "valgrind", see
> https://grasswiki.osgeo.org/wiki/GRASS_Debugging#Using_Valgrind
> That will give insights about potential memory leaks. He/you may CTRL-C
it on the way to keep the server alive.
A simple run fo v.select with valgrind does not show any memory leak
(increase of memory consumption within a loop). Can you provide the test
command and ideally also the data causing the problem? That would help with
debugging.
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190119/e038f899/attachment.html>
