[GRASS-dev] [GRASS GIS] #3475: r.mapcalc expression does not accept fully qualified map name as an output
GRASS GIS trac at osgeo.org
Fri Jan 25 23:53:45 PST 2019
  Reporter:  marisn       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  minor        |  Milestone:  7.2.4
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  r.mapcalc
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by Nikos Alexandris):
 Is there any activity on this? I have the following pending for a recently
 published add-on:
 {{{#!python
 /osgeo/grasstrunk/dist.x86_64-pc-linux-gnu/scripts/r.estimap.recreation
 --overwrite land=land_suitability at examples potential=potential
 syntax error, unexpected '@', expecting '('
 Parse error
 ERROR: parse error
   File "/osgeo/grasstrunk/dist.x86_64-pc-linux-
 gnu/scripts/r.estimap.recreation", line 4103, in <module>
     sys.exit(main())
 gnu/scripts/r.estimap.recreation", line 3631, in main
     r.mapcalc(subset_land)
 gnu/etc/python/grass/pygrass/modules/interface/module.py",
 line 651, in __call__
     return self.run()
 line 772, in run
     self.wait()
 line 797, in wait
     module=self.name, errors=stderr)
 grass.exceptions.CalledModuleError: Module run r.mapcalc
 r.mapcalc expression=tmp.5319.8.land_suitability at examples =
 land_suitability at examples region=current ended with error
 Process ended with non-zero return code 1. See errors in the
 (error) output.
 Removing temporary files
  Reading Glynn's last comment
 https://trac.osgeo.org/grass/ticket/676#comment:12, do I understand
 correctly that I should take care to strip '@mapset' part at the add-
 on/module level?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3475#comment:2>
