Or maybe, to be more flexible...
1. v.db.addtable doesn't create unique index
2. v.db.connect creates unique index "only if" there is no unique index
Just my 2 cents
On Sat, Jan 26, 2019 at 8:50 AM Huidae Cho <grass4u at gmail.com> wrote:
> Markus,
> If there is a linked table, v.db.addtable stops in line 106. If not, this
> script doesn't create a unique index and calls v.db.connect. v.db.connect
> adds a db link in line 317 and creates a unique index (db_create_index2) in
> line 334 if linking was successful. SQLite didn't complain when both
> modules created the same unique index, but PostgreSQL failed in
> v.db.connect (2nd time creating the same unique index). Not sure which code
> was added first/later. I think it's more of how we design both modules.
> v.db.connect will fail if we try to link a table with a unique index. Isn't
> v.db.connect supposed to "just" connect a table to a layer (without
> creating any database objects like index)? Which module should be
> responsible for creating unique indices?
> Before this commit:
> 1. v.db.addtable creates unique index
> 2. v.db.connect tries to create unique index again ==> fatal error
> After this commit:
> Probably, it should be:
> 1. v.db.addtable should create unique index
> 2. v.db.connect shouldn't try to create unique index? Just "connect"...
> Regards,
> Huidae
> On Sat, Jan 26, 2019 at 7:39 AM Markus Neteler <neteler at osgeo.org> wrote:
>> Hi,
>> On Tue, Jan 22, 2019 at 3:51 AM <svn_grass at osgeo.org> wrote:
>> > Author: hcho
>> > Date: 2019-01-21 18:51:33 -0800 (Mon, 21 Jan 2019)
>> > New Revision: 73995
>> > Modified:
>> > grass/trunk/scripts/v.db.addtable/v.db.addtable.py
>> > Log:
>> > v.db.addtable: Do not create unique index from this script;
>> v.db.connect will try to create it again causing some drivers to fail
>> (PostgreSQL)
>> > Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
>> > --- grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2019-01-21
>> 22:37:59 UTC (rev 73994)
>> > +++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2019-01-22
>> 02:51:33 UTC (rev 73995)
>> > @@ -139,16 +139,6 @@
>> > except CalledModuleError:
>> > grass.fatal(_("Unable to create table <%s>") % table)
>> > - # create index, see db/driver/*/index.c
>> > - if driver != "dbf":
>> > - sql = "CREATE UNIQUE INDEX %s_%s ON %s (%s)" % (table,
>> key, table, key)
>> > - try:
>> > - grass.run_command('db.execute',
>> > - database=database, driver=driver,
>> sql=sql)
>> > - except:
>> > - grass.warning(_("Unable to create index on table
>> <%s>") % table)
>> > - pass
>> > # connect the map to the DB:
>> > if schema:
>> > table = '{schema}.{table}'.format(schema=schema, table=table)
>> just a conceptual question:
>> ... are we sure that this index creation removal never leads to a
>> table without index?
>> Markus
> Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
> Open Source GIS Developer, GRASS GIS Development Team
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190126/9cff9f9a/attachment-0001.html>
