[GRASS-dev] Testsuite: script for easier use of test framework
Panagiotis Mavrogiorgos
pmav99 at gmail.com
Sun Jan 27 04:59:53 PST 2019
Since the testsuite script and its configuration file are committed, I
think it would be a good idea to also change the (hardcoded) default value
of GRASSSRC from:
# source code directory as full path:
> GRASSSRC="$HOME/software/grass77"
To something like:
GRASSSRC="$(cd ../../; pwd)"
> GRASSSRC="$(realpath ../../)"
So that you don't need to necessarily edit them in order to run them
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190127/71e932b7/attachment-0001.html>
