[GRASS-dev] [GRASS GIS] #3722: migrate grass svn repositories to git
trac at osgeo.org
Mon Jan 28 05:06:12 PST 2019
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: major | Milestone:
Component: Default | Version: unspecified
Resolution: | Keywords: svn, git, migration
CPU: Unspecified | Platform: Unspecified
Comment (by pmav99):
I don't have any experience with SVN to GIT conversions, but shouldn't
there be 70k+ commits?
I did run a couple of tests with subgit. It seems a solid project. If
someone wants to try it the commands for only converting trunk is (needs 6
hours):
subgit configure https://svn.osgeo.org/grass/grass/trunk --layout
directory grass_trunk.git
subgit install grass_full.git
The result is a repo with 36800+ commits which is comparable to 36743.
That's why I asked, if that was trunk only.
I also tried to convert the whole SVN repo:
subgit configure https://svn.osgeo.org/grass/grass --layout std
grass_full.git
but there is some problem with revision 68772. The logs suggest that it
has to do an old SVN bug: https://subversion.apache.org/docs/issue4129 .
This is the log:
SubGit version 3.3.5 ('Bobique') build #4042
Translating Subversion revisions to Git commits...
INSTALLATION FAILED
error: The Subversion repository is corrupted at revision r68772 because
of Subversion issue http://subversion.apache.org/docs/issue4129 .
error: To prevent this error in the futureupdate your Subversion server
version to 1.7.5 or to 1.6.18.
error: To recover your repository perform svnadmin dump/load procedure:
error: $ svnadmin dump path/to/svn/repository > repo.dump
error: $ svnadmin create path/for/recovered/svn/repository
error: $ svnadmin load path/for/recovered/svn/repository < repo.dump
error: After that please re-clone the repository.
error: svn: E204900: Checksum mismatch in
branches/releasebranch_7_2/lib/db/sqlp/sql.html: expected
7245ea62da02566d2edcab901919d4e9 but found
0061e8e51c3b551ac6123c88a66940cc
error: Checksum mismatch in
error: Unexpected error has occurred; please report along with the logs
('/home/username/Prog/svn/subgit-install-20190128-125015.zip')
error: to http://issues.tmatesoft.com/, thank you!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3722#comment:11>
