[GRASS-dev] [GRASS GIS] #3740: The GRASS session is "leaking" to the environment
trac at osgeo.org
Mon Jan 28 09:06:31 PST 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Startup | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Linux |
After closing the GRASS GUI the user account's local env is not being
restored. E.g.
$ echo $PATH
/home/pmav99/.local/bin:/usr/local/bin:/usr/local/sbin:/usr/lib/xpra:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
$ which python
/usr/bin/python
$ cat src2/grass/run_gui.sh
#!/usr/bin/env bash
# Run the GRASS GUI, after activating the virtualenv
# the 'dirname readlink' line finds the directory where this script is
located.
# https://stackoverflow.com/questions/59895/getting-the-source-directory-
of-a-bash-script-from-within
GRASS_SRC="$(dirname $(readlink -f $0))"
source "${GRASS_SRC}"/venv/bin/activate
exec "${GRASS_SRC}"/bin.x86_64-pc-linux-gnu/grass77
$ src2/grass/run_gui.sh
Starting GRASS GIS...
Cleaning up temporary files...
Welcome to GRASS GIS 7.7.svn (r74037)
[closing the gui]
$ echo $PATH
/home/pmav99/.local/bin:/home/pmav99/src2/grass/dist.x86_64-pc-linux-
gnu/bin:/home/pmav99/src2/grass/dist.x86_64-pc-linux-
gnu/scripts:/home/pmav99/.grass7/addons/bin:/home/pmav99/.grass7/addons/scripts:/home/pmav99/src2/grass/venv/bin:/home/pmav99/.local/bin:/usr/local/bin:/usr/local/sbin:/usr/lib/xpra:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
$ which python
/home/pmav99/src2/grass/venv/bin/python
As you can see $PATH has changed. Is this by design? Shouldn't the
original session be completely restored?
PS. Sorry if this has been mentioned before, but I couldn't find anything
relevant.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740>
