[GRASS-dev] [GRASS-SVN] r73995 - grass/trunk/scripts/v.db.addtable
Huidae Cho
grass4u at gmail.com
Tue Jan 29 13:12:23 PST 2019
Yes. Like you said, v.db.connect followed by v.db.connect -d gives me the
same pg errors and grass warning. I agree with you that the preferred
solution would be to create the index in v.db.addtable, not in v.db.connect
"if" no modules rely on v.db.connect for creating the unique index.
Huidae
On Tue, Jan 29, 2019 at 3:51 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Tue, Jan 29, 2019 at 4:12 PM Huidae Cho <grass4u at gmail.com> wrote:
> > You're right. It was a warning with PostgresSQL error messages (attached
> below), not a fatal error. But I don't think there should be any warning
> (or PostgreSQL errors) because the user didn't do anything wrong here
> (v.edit map tool=create; v.db.addtable).
> Hmm yes I agree. At least for v.db.addtable the index can be created by
> v.db.connect when the new table is actually linked to the vector map.
> You might still get these PG errors when you try to connect an already
> existing table, but this is probably not happening very often, and
> v.db.connect finishes anyway.
> Markus M
> > DBMI-PostgreSQL driver error:
> > Unable to create index: create unique index tmp2_cat on tmp2 ( cat )
> > ERROR: relation "tmp2_cat" already exists
> > WARNING: Cannot create index
> > here
> > WARNING: Values in column <cat> will be overwritten
> > Reading features...
> > 100%
> > Updating database...
> > 100%
> > Huidae
> > On Tue, Jan 29, 2019 at 9:37 AM Markus Metz <
> markus.metz.giswork at gmail.com> wrote:
> >> On Sun, Jan 27, 2019 at 11:21 AM Markus Metz <
> >> > On Sat, Jan 26, 2019 at 2:50 PM Huidae Cho <grass4u at gmail.com> wrote:
> >> > > Markus,
> >> > > If there is a linked table, v.db.addtable stops in line 106. If
> not, this script doesn't create a unique index and calls v.db.connect.
> v.db.connect adds a db link in line 317 and creates a unique index
> (db_create_index2) in line 334 if linking was successful. SQLite didn't
> complain when both modules created the same unique index, but PostgreSQL
> failed in v.db.connect (2nd time creating the same unique index).
> >> What do you mean with "failed"? v.db.connect will issue a warning if it
> can not create an index but finish successfully.
> >> Markus M
> >> >> Not sure which code was added first/later. I think it's more of how
> we design both modules. v.db.connect will fail if we try to link a table
> with a unique index. Isn't v.db.connect supposed to "just" connect a table
> to a layer (without creating any database objects like index)? Which module
> should be responsible for creating unique indices?
> >> > > Before this commit:
> >> > > 1. v.db.addtable creates unique index
> >> > > 2. v.db.connect tries to create unique index again ==> fatal error
> >> > > After this commit:
> >> > > 1. v.db.addtable doesn't create unique index
> >> > > 2. v.db.connect creates unique index
> >> > > Probably, it should be:
> >> > > 1. v.db.addtable should create unique index
> >> > > 2. v.db.connect shouldn't try to create unique index? Just
> "connect"...
> >> > Yes, this is the preferred solution. Consider v.db.connect -d
> followed by v.db.connect, i.e. disconnecting a table and then reconnecting
> the same table: in this case v.db.connect should also fail with PostgreSQL.
> IMHO, a unique index should only be created when the table is created.
> >> > Markus M
> >> > > Regards,
> >> > > Huidae
> >> > > On Sat, Jan 26, 2019 at 7:39 AM Markus Neteler <neteler at osgeo.org>
> wrote:
> >> > >> Hi,
> >> > >> On Tue, Jan 22, 2019 at 3:51 AM <svn_grass at osgeo.org> wrote:
> >> > >> > Author: hcho
> >> > >> > Date: 2019-01-21 18:51:33 -0800 (Mon, 21 Jan 2019)
> >> > >> > New Revision: 73995
> >> > >> > Modified:
> >> > >> > grass/trunk/scripts/v.db.addtable/v.db.addtable.py
> >> > >> > Log:
> >> > >> > v.db.addtable: Do not create unique index from this script;
> v.db.connect will try to create it again causing some drivers to fail
> (PostgreSQL)
> >> > >> > Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
> >> > >> > --- grass/trunk/scripts/v.db.addtable/v.db.addtable.py
> 2019-01-21 22:37:59 UTC (rev 73994)
> >> > >> > +++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py
> 2019-01-22 02:51:33 UTC (rev 73995)
> >> > >> > @@ -139,16 +139,6 @@
> >> > >> > except CalledModuleError:
> >> > >> > grass.fatal(_("Unable to create table <%s>") %
> table)
> >> > >> > - # create index, see db/driver/*/index.c
> >> > >> > - if driver != "dbf":
> >> > >> > - sql = "CREATE UNIQUE INDEX %s_%s ON %s (%s)" %
> (table, key, table, key)
> >> > >> > - try:
> >> > >> > - grass.run_command('db.execute',
> >> > >> > - database=database,
> driver=driver, sql=sql)
> >> > >> > - except:
> >> > >> > - grass.warning(_("Unable to create index on
> table <%s>") % table)
> >> > >> > - pass
> >> > >> > # connect the map to the DB:
> >> > >> > if schema:
> >> > >> > table = '{schema}.{table}'.format(schema=schema,
> table=table)
> >> > >> just a conceptual question:
> >> > >> ... are we sure that this index creation removal never leads to a
> >> > >> table without index?
> >> > >> Markus
> >> > > Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
> >> > > Open Source GIS Developer, GRASS GIS Development Team
> >> > > _______________________________________________
> >> > > grass-dev mailing list
> >> > > grass-dev at lists.osgeo.org
> >> > > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190129/38ee83b3/attachment-0001.html>
