[GRASS-dev] [GRASS GIS] #3740: The "Quit GRASS GIS" button does not close the GRASS shell/session
    trac at osgeo.org
    Tue Jan 29 14:46:01 PST 2019
  Reporter:  pmav99   |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:
 Component:  Startup  |    Version:  svn-trunk
Resolution:           |   Keywords:
       CPU:  x86-64   |   Platform:  Linux
Comment (by pmav99):
 I don't really understand why, but the problem might be related with zsh
 after all...
 On zsh, which is what I mainly use, I get the problems I mentioned
 earlier. On bash though, the button exits GRASS just fine. I tested this
 both on the Ubuntu VM and on Archlinux.
 Note: If you want to try this, you don't only need to start a zsh shell,
 you also need to `export SHELL=/usr/bin/zsh` too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3740#comment:11>
