[GRASS-dev] [GRASS GIS] #3739: lib/python/ctypes/ctypesgencore/parser/lextab.py changes after compilation.
trac at osgeo.org
Wed Jan 30 08:51:59 PST 2019
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by pmav99):
Not really. I don't have much experience with ctypes, but I am under the
impression that this will file will be different under each python version
(2.7 vs 3.6/3.7). Maybe even under different minor versions too but I
haven't checked it.
So if it gets committed for Python 3, I guess that there is going to be a
dirty `svn diff` under Python 2.
Furthermore, since this file is clearly changing when GRASS is compiled, I
am not really sure why it is added to the repo, instead of getting
generated upon compilation.
Finally, there have already been 2 instances where the file was
accidentally added to the repo, only to be removed right away:
https://trac.osgeo.org/grass/log/grass/trunk/lib/python/ctypes/ctypesgencore?rev=74047
So, before deciding on a course of action, I think it is better to further
investigate how it is being used/generated. This might provide some
insight: #3331
Ticket URL: <https://trac.osgeo.org/grass/ticket/3739#comment:4>
