[GRASS-dev] [GRASS-SVN] r73995 - grass/trunk/scripts/v.db.addtable
Huidae Cho grass4u at gmail.com
Wed Jan 30 15:21:28 PST 2019
r74043 works.
Thanks,
Huidae
On Wed, Jan 30, 2019 at 4:20 AM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Wed, Jan 30, 2019 at 9:42 AM Markus Metz <markus.metz.giswork at gmail.com>
> wrote:
> > On Tue, Jan 29, 2019 at 11:37 PM Huidae Cho <grass4u at gmail.com> wrote:
> > > Just for our records, actually, PostgreSQL 9.5+ supports CREATE INDEX
> IF NOT EXISTS, which the grass sqlite driver already does (this is why we
> didn't have this warning with sqlite before). Not sure if we want to
> enforce the minimum version for a specific database though.
> > We can use "if not exists" for PostgreSQL 9.5+, otherwise not, please
> try trunk r74042.
> trunk r74043
> > Markus M
> > > Best,
> > > Huidae
> > > On Tue, Jan 29, 2019 at 5:16 PM Huidae Cho <grass4u at gmail.com> wrote:
> > >> I just did a quick search and found that these modules
> (i.segment.stats, r.mwprecip, v.in.geopaparazzi, v.link.precip, v.out.gps,
> v.ply.rectify, v.unpack) create/copy new tables themselves without the
> index and invoke v.db.connect. For now, we cannot move index creation to
> v.db.addtable.
> > >> Huidae
> > >> On Tue, Jan 29, 2019 at 4:12 PM Huidae Cho <grass4u at gmail.com> wrote:
> > >>> Yes. Like you said, v.db.connect followed by v.db.connect -d gives
> me the same pg errors and grass warning. I agree with you that the
> preferred solution would be to create the index in v.db.addtable, not in
> v.db.connect "if" no modules rely on v.db.connect for creating the unique
> index.
> > >>> Huidae
> > >>> On Tue, Jan 29, 2019 at 3:51 PM Markus Metz <
> wrote:
> > >>>> > You're right. It was a warning with PostgresSQL error messages
> (attached below), not a fatal error. But I don't think there should be any
> warning (or PostgreSQL errors) because the user didn't do anything wrong
> here (v.edit map tool=create; v.db.addtable).
> > >>>> Hmm yes I agree. At least for v.db.addtable the index can be
> created by v.db.connect when the new table is actually linked to the vector
> map.
> > >>>> You might still get these PG errors when you try to connect an
> already existing table, but this is probably not happening very often, and
> v.db.connect finishes anyway.
> > >>>> Markus M
> > >>>> > DBMI-PostgreSQL driver error:
> > >>>> > Unable to create index: create unique index tmp2_cat on tmp2 (
> cat )
> > >>>> > ERROR:  relation "tmp2_cat" already exists
> cat )
> > >>>> > WARNING: Cannot create index
> > >>>> > here
> > >>>> > WARNING: Values in column <cat> will be overwritten
> > >>>> > Reading features...
> > >>>> >  100%
> > >>>> > Updating database...
> > >>>> >  100%
> > >>>> > Huidae
> > >>>> > On Tue, Jan 29, 2019 at 9:37 AM Markus Metz <
> > >>>> >> On Sun, Jan 27, 2019 at 11:21 AM Markus Metz <
> > >>>> >> > On Sat, Jan 26, 2019 at 2:50 PM Huidae Cho <grass4u at gmail.com>
> wrote:
> > >>>> >> > > Markus,
> > >>>> >> > > If there is a linked table, v.db.addtable stops in line 106.
> If not, this script doesn't create a unique index and calls v.db.connect.
> v.db.connect adds a db link in line 317 and creates a unique index
> (db_create_index2) in line 334 if linking was successful. SQLite didn't
> complain when both modules created the same unique index, but PostgreSQL
> failed in v.db.connect (2nd time creating the same unique index).
> > >>>> >> What do you mean with "failed"? v.db.connect will issue a
> warning if it can not create an index but finish successfully.
> > >>>> >> Markus M
> > >>>> >> >> Not sure which code was added first/later. I think it's more
> of how we design both modules. v.db.connect will fail if we try to link a
> table with a unique index. Isn't v.db.connect supposed to "just" connect a
> table to a layer (without creating any database objects like index)? Which
> module should be responsible for creating unique indices?
> > >>>> >> > > Before this commit:
> > >>>> >> > > 1. v.db.addtable creates unique index
> > >>>> >> > > 2. v.db.connect tries to create unique index again ==> fatal
> error
> > >>>> >> > > After this commit:
> > >>>> >> > > 1. v.db.addtable doesn't create unique index
> > >>>> >> > > 2. v.db.connect creates unique index
> > >>>> >> > > Probably, it should be:
> > >>>> >> > > 1. v.db.addtable should create unique index
> > >>>> >> > > 2. v.db.connect shouldn't try to create unique index? Just
> "connect"...
> > >>>> >> > Yes, this is the preferred solution. Consider v.db.connect -d
> followed by v.db.connect, i.e. disconnecting a table and then reconnecting
> the same table: in this case v.db.connect should also fail with PostgreSQL.
> IMHO, a unique index should only be created when the table is created.
> > >>>> >> > Markus M
> > >>>> >> > > Regards,
> > >>>> >> > > Huidae
> > >>>> >> > > On Sat, Jan 26, 2019 at 7:39 AM Markus Neteler <
> neteler at osgeo.org> wrote:
> > >>>> >> > >> Hi,
> > >>>> >> > >> On Tue, Jan 22, 2019 at 3:51 AM <svn_grass at osgeo.org>
> wrote:
> > >>>> >> > >> > Author: hcho
> > >>>> >> > >> > Date: 2019-01-21 18:51:33 -0800 (Mon, 21 Jan 2019)
> > >>>> >> > >> > New Revision: 73995
> > >>>> >> > >> > Modified:
> > >>>> >> > >> >    grass/trunk/scripts/v.db.addtable/v.db.addtable.py
> > >>>> >> > >> > Log:
> > >>>> >> > >> > v.db.addtable: Do not create unique index from this
> script; v.db.connect will try to create it again causing some drivers to
> fail (PostgreSQL)
> > >>>> >> > >> > Modified: grass/trunk/scripts/v.db.addtable/
> v.db.addtable.py
> > >>>> >> > >> > --- grass/trunk/scripts/v.db.addtable/v.db.addtable.py
>  2019-01-21 22:37:59 UTC (rev 73994)
> > >>>> >> > >> > +++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py
>  2019-01-22 02:51:33 UTC (rev 73995)
> > >>>> >> > >> > @@ -139,16 +139,6 @@
> > >>>> >> > >> >          except CalledModuleError:
> > >>>> >> > >> >              grass.fatal(_("Unable to create table <%s>")
> % table)
> > >>>> >> > >> > -        # create index, see db/driver/*/index.c
> > >>>> >> > >> > -        if driver != "dbf":
> > >>>> >> > >> > -            sql = "CREATE UNIQUE INDEX %s_%s ON %s (%s)"
> % (table, key, table, key)
> > >>>> >> > >> > -            try:
> > >>>> >> > >> > -                grass.run_command('db.execute',
> > >>>> >> > >> > -                                  database=database,
> driver=driver, sql=sql)
> > >>>> >> > >> > -            except:
> > >>>> >> > >> > -                grass.warning(_("Unable to create index
> on table <%s>") % table)
> > >>>> >> > >> > -                pass
> > >>>> >> > >> >      # connect the map to the DB:
> > >>>> >> > >> >      if schema:
> > >>>> >> > >> >          table = '{schema}.{table}'.format(schema=schema,
> table=table)
> > >>>> >> > >> just a conceptual question:
> > >>>> >> > >> ... are we sure that this index creation removal never
> leads to a
> > >>>> >> > >> table without index?
> > >>>> >> > >> Markus
> > >>>> >> > > Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
> > >>>> >> > > Open Source GIS Developer, GRASS GIS Development Team
> > >>>> >> > > _______________________________________________
> > >>>> >> > > grass-dev mailing list
> > >>>> >> > > grass-dev at lists.osgeo.org
> > >>>> >> > > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190130/bfa08825/attachment-0001.html>
