[GRASS-dev] [GRASS GIS] #3745: gunittest reporter message improvement
GRASS GIS trac at osgeo.org
Thu Jan 31 01:38:33 PST 2019
 Reporter:  neteler            |      Owner:  grass-dev@…
     Type:  defect             |     Status:  new
 Priority:  normal             |  Milestone:  7.8.0
Component:  Tests              |    Version:  svn-trunk
 Keywords:  python, gunittest  |        CPU:  All
 Platform:  All                |
 I tried to improve the unit test reporting message with a small detail:
 adding
 the amount of total tests. My attempt is the attached patch but it doesn't
 really work:
 test_v_rast_stats from ./scripts/v.rast.stats failed (3 tests out of 6
 failed)
 test_what_strds from ./scripts/v.what.strds failed (1 test out of 1
 failed)
 test.t.vect.list from ./temporal/t.vect.list failed
 test.t.merge from ./temporal/t.merge failed
 test.t.vect.observe.strds.relative from ./temporal/t.vect.observe.strds
 failed
 test.t.vect.observe.strds from ./temporal/t.vect.observe.strds failed
 test_snap from ./temporal/t.snap failed (6 tests out of 6 failed)
 test_raster_algebra from ./temporal/t.rast.algebra failed (77 tests
 out of 40 failed)
 In any case, the percentage might be better but no idea how to extract
 that.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3745>
