[GRASS-dev] [GRASS GIS] #3863: epsg file missing in GRASS 7.6.1 stable
trac at osgeo.org
Wed Jul 3 00:34:28 PDT 2019
Reporter: Luigi Ponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: Projections/Datums | Version: svn-releasebranch76
Resolution: | Keywords: epsg
CPU: OSX/Intel | Platform: MacOSX
Comment (by mmetz):
Replying to [comment:2 Luigi Ponti]:
> I wonder why the bundle was built with an incompatible proj-6 libary --
it that going to break a lot of GRASS functionality other than the missing
epsg file?
Yes, reprojections are affected because the bahviour of proj changed:
previously, it expected coordinates in the order east, north. Now it
depends on the CRS definition, e.g. commonly used EPSG:4326 defines an
order of north, east. Previously it expected coordinates for ll to be in
radians, now it also depends on the CRS definition (commonly degrees, not
radians for ll). That means even if you patch in the old epsg file,
coordinate transformations might be wrong. Not to mention the new temporal
dimension and the new availability of more accurate transformation
pipelines.
> Should I close the bug as it is apparently not a bug?
Maybe we should add a configure check for proj-6+ to GRASS 7.6.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3863#comment:3>
