[GRASS-dev] [GRASS GIS] #3865: i.spec.unmix: map writeout broken
GRASS GIS trac at osgeo.org
Thu Jul 4 05:48:35 PDT 2019
 Reporter:  neteler       |      Owner:  grass-dev@…
     Type:  defect        |     Status:  new
 Priority:  normal        |  Milestone:
Component:  Imagery       |    Version:  unspecified
 Keywords:  i.spec.unmix  |        CPU:  x86-64
 Platform:  Unspecified   |
 For unknow reasons i.spec.unmix is unable to write out the resulting maps:
 GRASS 7.7.dev (nc_spm_08_grass7):~ >
 g.region raster=lsat7_2002_10 -p
 nsres:      28.5
 ewres:      28.5
 rows:       475
 cols:       527
 cells:      250325
 i.spec.unmix group=lsat_2002 matrix=spectrum.txt result=lsat7_2002_unmix
 error=lsat7_2002_unmix_err iter=lsat7_2002_unmix_iterations
 D0/0: buff: Matrix:     5 by 7
 Opening input file no. 1 [lsat7_2002_10]
 Opening input file no. 2 [lsat7_2002_20]
 Opening input file no. 3 [lsat7_2002_30]
 Opening input file no. 4 [lsat7_2002_40]
 Opening input file no. 5 [lsat7_2002_50]
 Opening input file no. 6 [lsat7_2002_70]
 Opening input file no. 7 [lsat7_2002_80]
 Opening output file [lsat7_2002_unmix.1]
 Opening output file [lsat7_2002_unmix.2]
 Opening output file [lsat7_2002_unmix.3]
 Opening output file [lsat7_2002_unmix.4]
 Opening output file [lsat7_2002_unmix.5]
 Opening error file [lsat7_2002_unmix_err]
 Opening iteration file [lsat7_2002_unmix_iterations]
 Checking linear dependencies (orthogonality check) of Matrix A...
 Angle between row 1 and row 2: 60.9753 degree
 Angle between row 1 and row 3: 56.5953 degree
 Angle between row 1 and row 4: 34.7591 degree
 Angle between row 1 and row 5: 43.122 degree
 Angle between row 2 and row 1: 60.9753 degree
 Angle between row 2 and row 3: 42.7788 degree
 Angle between row 2 and row 4: 35.7377 degree
 Angle between row 2 and row 5: 40.2744 degree
 Angle between row 3 and row 1: 56.5953 degree
 Angle between row 3 and row 2: 42.7788 degree
 Angle between row 3 and row 4: 32.3279 degree
 Angle between row 3 and row 5: 28.9019 degree
 Angle between row 4 and row 1: 34.7591 degree
 Angle between row 4 and row 2: 35.7377 degree
 Angle between row 4 and row 3: 32.3279 degree
 Angle between row 4 and row 5: 28.552 degree
 Angle between row 5 and row 1: 43.122 degree
 Angle between row 5 and row 2: 40.2744 degree
 Angle between row 5 and row 3: 28.9019 degree
 Angle between row 5 and row 4: 28.552 degree
 Spectral matrix is o.k. Proceeding...
 Calculating for 475 x 527 pixels (7 bands) = 277729 pixelvectors.
  100%
 ERROR: Unable to open header file for raster map
        <lsat7_2002_unmix.1 at PERMANENT>
 Since i.spec.unmix was ported from GRASS 5 years ago, perhaps some raster
 function usage is not correct?
 I have attached the input matrix of endmembers for easy testing.
 Ideas welcome!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3865>
