[GRASS-dev] [GRASS GIS] #3867: menudata.py: global name 'error_handler' is not defined
GRASS GIS trac at osgeo.org
Tue Jul 9 01:38:00 PDT 2019
  Reporter:  marisn       |      Owner:  wenzeslaus
      Type:  defect       |     Status:  assigned
  Priority:  normal       |  Milestone:
 Component:  wxGUI        |    Version:  svn-trunk
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by marisn):
 Replying to [comment:1 annakrat]:
 > The fix is rather simple, but could you please test
 https://github.com/OSGeo/grass/pull/43? I was not able to test and I
 wonder why do you get that error at all.
 Yes, whit this fix it is possible to get one step further:
 /usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py:16629:
 UserWarning: wxPython/wxWidgets release number mismatch
   warnings.warn("wxPython/wxWidgets release number mismatch")
 r.agent: Unable to fetch interface description for command '<r.agent>'.
 Details: <[Errno 2] No such file or directory>
   File "/home/maris/soft/grass-main/dist.x86_64-pc-linux-
 gnu/gui/wxpython/wxgui.py", line 172, in <module>
     sys.exit(main())
 gnu/gui/wxpython/wxgui.py", line 159, in main
     app = GMApp(workspaceFile)
 gnu/gui/wxpython/wxgui.py", line 53, in __init__
     wx.App.__init__(self, False)
   File "/usr/lib64/python2.7/site-packages/wx-3.0-gtk2/wx/_core.py", line
 8628, in __init__
     self._BootstrapApp()
 8196, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
 gnu/gui/wxpython/wxgui.py", line 106, in OnInit
     workspace=self.workspaceFile)
 gnu/gui/wxpython/lmgr/frame.py", line 131, in __init__
     self._moduleTreeBuilder =
 LayerManagerModuleTree(message_handler=add_menu_error)
 gnu/gui/wxpython/lmgr/menudata.py", line 73, in __init__
     self, fallback, message_handler=message_handler)
 gnu/gui/wxpython/core/menutree.py", line 73, in __init__
     expAddons(xmlTree)
 gnu/gui/wxpython/core/toolboxes.py", line 363, in expandAddons
     _expandRuntimeModules(root, loadMetadata=True)
 gnu/gui/wxpython/core/toolboxes.py", line 626, in _expandRuntimeModules
     desc, keywords = _loadMetadata(name)
 gnu/gui/wxpython/core/toolboxes.py", line 663, in _loadMetadata
     task = gtask.parse_interface(module)
 gnu/etc/python/grass/script/task.py", line 521, in parse_interface
     tree = etree.fromstring(get_interface_description(name))
 gnu/etc/python/grass/script/task.py", line 497, in
     "\n\nDetails: <{det}>".format(cmd=cmd, det=decode(cmderr))))
 UnicodeEncodeError: 'ascii' codec can't encode characters in position 1-2:
 ordinal not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3867#comment:2>
