[GRASS-dev] [GRASS GIS] #3869: v.import add missing v.in.ogr options
GRASS GIS trac at osgeo.org
Tue Jul 9 13:06:24 PDT 2019
  Reporter:  lucadelu     |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.8.0
 Component:  Vector       |    Version:  unspecified
Resolution:               |   Keywords:  v.import options
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:2 lucadelu]:
 > Replying to [comment:1 mmetz]:
 > > v.import is (was) meant to be an easy to use module with a simple
 interface for importing vector data. The idea was that if you want more
 control or more options you can use the more advanced module v.in.ogr.
 > [...] I was at JRC for a meeting about INSPIRE support and I discovered
 a really useful option to use in gdal_doo to have a better support for GML
 files. I think it is important to have this capability also in v.import
 for example
 The gdal_doo option is IMHO an advanced option: you need to know to the
 OGR driver needed to read this dataset, and you need to read the GDAL/OGR
 documentation for this particular driver to know which dataset open
 options (or GDAL configuration options) are needed to properly read this
 particular dataset.
 Thinking about it, it is ok to provide all options of v.in.ogr and v.proj
 also in v.import, as long as they go into separate gui sections, something
 like "advanced".
 Maybe there should be a gui section "dangerous" for the v.in.ogr -o flag
 and the v.import options epsg and datum_trans.
 Considering the substantial changes in PROJ 6+, it might no longer be
 possible to do fully automated reprojection, instead users need in some
 cases select the appropriate reprojection method for their particular
 data: there can be several methods available to transform coordinates from
 one CRS to another CRS, users have to decide which one to use. Just as a
 warning that v.import might not work as expected with proj 6+ and gdal 3+
 in future releases of GRASS GIS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3869#comment:3>
