[GRASS-dev] [GRASS GIS] #3867: menudata.py: global name 'error_handler' is not defined
trac at osgeo.org
Wed Jul 10 03:42:35 PDT 2019
Reporter: marisn | Owner: wenzeslaus
Type: defect | Status: assigned
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by marisn):
Replying to [comment:3 annakrat]:
> Can't reproduce it. Anything special about your configuration? I can see
wxPython 3 and Python 2. Which addons do you have installed? It happens
during loading info about installed addons.
Ah. I see. You will need some broken addons thus triggering error
processing code paths. You also will need a locale with non-ascii chars in
particular message causing failure :) Try running with LC_ALL=lv_LV
Python 2.7.16
wxpython-3.0.2.0
wxGTK-3.0.4
Gentoo ~AMD64
Ticket URL: <https://trac.osgeo.org/grass/ticket/3867#comment:4>
