[GRASS-dev] wingrass builds status (git recover)
Huidae Cho
grass4u at gmail.com
Wed Jul 10 15:37:31 PDT 2019
Hello, I experienced the exact same issue on Windows. One of my PRs should
fix it.
Regards,
Huidae
Huidae Cho, Ph.D., GISP, PE (MD), CFM, M.ASCE
Open Source GIS Developer, GRASS GIS Development Team
https://idea.isnew.info
Sent from my phone
On Sun, Jul 7, 2019, 3:53 PM Helmut Kudrnovsky <hellik at web.de> wrote:
> Hi Martin,
> Martin Landa wrote
> > Hi,
> > I have recovered (at least partially) wingrass builds:
> > * daily builds (GRASS 7.6 & 7.7: only 64bit builds) [standalone [1] &
> > osgeo4w/grass-daily) are operational
> > Up-to-date maintenance scripts available at [2].
> > In next days I will re-cover grass74 daily builds and more importantly
> > release addons builds (7.4.4 & 7.6.1).
> thanks for your effort to bring winGRASS daily builds back
> tested here with the OSGeo4W 64bit dailys.
> following issue when downloading OSGeo4W grass-daily-7.7.dev-f79c3568d-1:
> ° g.mkfontcap.exe - system error because libgraphite2.dll and libpcre-1.dll
> can't be found
> ° "inflateValidate" in the dll
> C:\OSGeo4W\apps\grass\grass77\bin\libpng16-16.dll can't be found
> regarding the last issue item, in C:\OSGeo4W\apps\grass\grass77\bin\ there
> shouldn't be any foreign dll, right?
> looking into it
> C:\OSGeo4W64\apps\grass\grass77\bin>ls | grep lib
> libbz2-1.dll
> libexpat-1.dll
> libfontconfig-1.dll
> libfreetype-6.dll
> libgcc_s_seh-1.dll
> libglib-2.0-0.dll
> libharfbuzz-0.dll
> libiconv-2.dll
> libintl-8.dll
> libpng16-16.dll
> libstdc++-6.dll
> libsystre-0.dll
> libtre-5.dll
> libwinpthread-1.dll
> test.raster3d.lib.exe
> zlib1.dll
> downloading
> https://wingrass.fsv.cvut.cz/grass77/x86_64/osgeo4w/grass-daily-7.7.dev-f79c3568d-1.tar.bz2
> D:\temp\wwf\grass-daily-7.7.dev-f79c3568d-1.tar\grass-daily-7.7.dev-f79c3568d-1\apps\grass\grass77\bin>ls
> | grep lib
> libbz2-1.dll
> libexpat-1.dll
> libfontconfig-1.dll
> libfreetype-6.dll
> libgcc_s_seh-1.dll
> libglib-2.0-0.dll
> libharfbuzz-0.dll
> libiconv-2.dll
> libintl-8.dll
> libpng16-16.dll
> libstdc++-6.dll
> libsystre-0.dll
> libtre-5.dll
> libwinpthread-1.dll
> zlib1.dll
> these dlls are in
> any idea about that?
> these dlls maybe are the reason for
> Starting GRASS GIS...
> WARNUNG: Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows
> nicht möglich.
> Cleaning up temporary files...
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Welcome to GRASS GIS 7.7.dev
> GRASS GIS homepage: https://grass.osgeo.org
> This version running through: Command Prompt
> (C:\WINDOWS\system32\cmd.exe)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> See citation options with: g.version -x
> If required, restart the GUI with: g.gui wxpython
> When ready to quit enter: exit
> Launching <wxpython> GUI in the background, please wait...
> Microsoft Windows [Version 10.0.18362.175]
> (c) 2019 Microsoft Corporation. Alle Rechte vorbehalten.
> C:\>C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\wxgui.py:101:
> DeprecationWarning: Yield() is deprecated
> wx.Yield()
> GRASS Modul 'g.proj' nicht gefunden. Kann Kartenfenster nicht starten.
> Error in atexit._run_exitfuncs:
> wx._core.wxAssertionError: C++ assertion "GetEventHandler() == this" failed
> at ..\..\src\common\wincmn.cpp(478) in wxWindowBase::~wxWindowBase(): any
> pushed event handlers must have been removed
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190710/3b01b758/attachment.html>
